Results 1 to 2 of 2
Thread: How to change a low-beam headlight bulb in a Mitsubishi Magna TJ AWD Sports:
    WSDsmurf's Avatar
    Mar 2004
    Default How to change a low-beam headlight bulb in a Mitsubishi Magna TJ AWD Sports:
    - Read up on forums and car handbook on how to change low-beam light-bulb.
    - Go to Repco.
    - Get new TJ Magna low beam bulb from Repco (H4).
    - Note need to remove washer bottle.
    - Find that removing 10mm washer bottle retention bots with crappy $2 spanner is a mug's game.
    - Find that you don't actually possess a 10mm socket..... So mug's game it is then.
    - Accidentally pull out washer pump motor while attempting to remove washer bottle.
    - Remove washer bottle.
    - Undo bulb hard cover.
    - Remove bulb weather seal.
    - Find out that MMAL lightbulb retention spring is as confusing to figure out as legend has it.
    - Remove bulb.
    - Find that Repco replacement blub for TJ Magna (H4) is not suitable for TJ Magna AWD (H7).....
    - Complete kicking inanimate object found close to hand.
    - Replace bulb, Replace MMAL spring, Replace weather seal, Replace hard cover.
    - Return to Repco.
    - Find proper TJ AWD Magna low-beam bulb (which is cunningly listed as for only KJ Verada) (being the H7... not a H4 bulb).
    - Decide mug's game is silly, so also purchase a proper socket set.
    - Return to car.
    - Remove hard cover, Remove weather seal, Remove MMAL spring, Remove old bulb.
    - Put in new bulb.
    - Replace MMAL spring, Replace weather seal, Replace hard cover.
    - (Remove randomly found 100w siren given opportunity of vacant washer bottle).
    - Attempt to re-insert washer pump motor.
    - Re-attempt to re-insert washer pump motor.
    - Lubricate and re-insert washer pump motor.
    - Replace washer bottle with newly acquired socket set (10mm).
    - Refill washer bottle and check for leaks.
    - Reconnect power to washer pump motor.
    - Find that windscreen washer jets don't work.
    - Disconnect washer jet hoses and bleed hoses.
    - Find windscreen washer jets work.
    - Clean up.
    - Find that you actually DID own a 10mm socket all along.
    - Bang head against wall until ineptitude goes away.
    Sparky's Avatar
    Feb 2010
    Like
    1992 Mitsubishi magna
    QMD Fursuiter
    Im always in TROUBLE no matter where I am.
